Cracked head on -1947 A
shawmic
09-17-2007 09:06:54
Any fix ideas for a cracked head on John Deere A--Must have frozen? When tractor is started --Water runs out from gasket area that leads to the radiator and also cracks near the drain plug. Is a product like JB Weld a possible fix? Thanks.
Lee B
09-18-2007 20:31:01
 Re: Cracked head on -1947 A in reply to shawmic, 09-17-2007 09:06:54
In order for JB Weld to work good one would have to clean the cracked edges and get the JB Weld material in there. IF you can do that then yes, it's a good choice. It might still work with less than perfect conditions too.
I would use RTV silicone on the gasket for sure and maybe JB Weld on the drain plug cracks depending on how clean and dry I could get them. And then there is always Bar's leak brand stop leak. Four or five large bottles of which will always be cheaper than head work or used parts with no waiting either.
Rob in MI
09-18-2007 18:09:26
I have a good head from a 1950 A. If it will fit I will sell it to you at a good price.
37joshjd
09-17-2007 18:28:16
A good welder can repair it if he knows what he is doing. JB weld will work if you get the area clean but if your like me you always worry about it.
Maark
09-17-2007 18:14:05
I've removed the head and v'd out the crack and welded a couple of heads back that were broken in the very same spot with good luck. I used nickel 99 welding rod. very easy to use.
Paul from MI
09-17-2007 16:58:06
I had the head on my 1941 A crack around a valve seat. I had it repaired at our local machine shop. They used a series of interlocking tapered cast iron plug threaded into tapped holes in the head to plug the crack. It's been over 20 years and no problems(knock on wood). I would think a similar fix would work for you. Since your leak is to the outside, not into a cylinder, a slight amount of seepage isn't so serious. I'd use a good block sealer after you get the head fixed.
Good luck,
Paul
RobMD
09-17-2007 10:07:41
You sure it's the head, and not an overtightened drain plug??
shawmic
09-17-2007 13:23:16
 Re: Cracked head on -1947 A in reply to RobMD, 09-17-2007 10:07:41
The gasket is forced out and with the drain plug in-- I see at least 2 cracks -- 3/4" in length near the plug.
