1947 Late styled A fenders
craig reavley
09-17-2007 07:25:04
Where can I buy fenders for a 1947 late styled A I believe I have the round final drive and will need a bracket as well. I need both fenders and brackets and a price
third party image
CLW
09-19-2007 21:19:23
 Re: 1947 Late styled A fenders in reply to craig reavley, 09-17-2007 07:25:04
Two-Cylinder July-Aug 1998 says the 47 A would use AA1582R and AA1583R full crown fenders and would bolt to the front of the axle housing. No brackets required. If you use the clamshell fenders that were made for the square axle you will need brackets.
Dave in SV
09-17-2007 11:42:23
Off subject I know... but what's the round tube just above the PowerTrol, behind the battery box?
Maark
09-17-2007 13:04:56
 Re: 1947 Late styled A fenders in reply to Dave in SV, 09-17-2007 11:42:23
That round tube is extra resevoir for hydraulic oil.
Dave in SV
09-17-2007 13:31:50
 Re: 1947 Late styled A fenders in reply to Maark, 09-17-2007 13:04:56
Ah ha... thanks.
I'm always "spying" other A's, to see what mine might be missing. Since I don't use the PowerTrol, nor do I imagine I ever will, I probably don't need the extra tank... but it sure looks cool!
Mike M
09-17-2007 08:13:47
 Re: 1947 Late styled A fenders in reply to RobMD, 09-17-2007 08:02:20
There's a special cast bracket to go from round axle tube to the clamshells.I have an original set. I even think it is pictured in some of the parts books ? Aftermarket does make them too.
Mike M
09-17-2007 08:01:42
You can go with the over top the tire ones no brackets needed or the clamshell ones with adapter brackets. Used ones around and New reproduction being made too.As far as prices ??? I see them in the trade magazines and ebay. Either way they are going to make getting on and off really tight !
two cylinders saves gas
09-18-2007 17:02:53
 Re: 1947 Late styled A fenders in reply to Mike M, 09-17-2007 08:01:42
lol mike i hope he weighs less than 200 pounds or forget it
The Dukester
09-17-2007 19:03:26
The big curved over the tire type fenders came on '47 A's, and they do make mounting up a little difficult if you're big. The later clamshell type look okay if you're not going for correct and they can be positioned wider to allow more room if you need it. The new clamshells and the needed brackets cost about the same as properly made new over-the-toppers.
