JD 14T dimensions
YAB
09-17-2007 06:58:32
I"m thinking about traveling to pick up a 14T. I wanted to know the width, length and approx. weight of the baler for trailer sizing. Can anyone provide me with that information? Thanks.
`Bernie in MA
09-17-2007 16:35:41
 Re: JD 14T dimensions in reply to YAB, 09-17-2007 06:58:32
If you are putting it on a truck or trailer you will need a small wheel assembly that clamps to the frame inside the righthand wheel so that the baler wheel can hang off the outsde edge of the truck/trailer. You should be able to borrow one from an older dealer.
YAB
09-17-2007 17:37:12
 Re: JD 14T dimensions in reply to `Bernie in MA, 09-17-2007 16:35:41
Bernie,
How big a trailer would I need?
Thx
TimS in Mo
09-19-2007 08:46:08
 Re: JD 14T dimensions in reply to YAB, 09-17-2007 17:37:12
They are just over 8 feet wide, so you will need a trailer with a deck over the tires or you will need a way to pick it up and set it down on the trailer at an angle. ( forklifts, etc )
Weight wise I think they are around 3500-4000 pounds, I had one but can't remember what the weight was listed at in the manual.
