52 Plow coulter
Jason Z in MO
09-16-2007 18:50:03
I picked up a 52 plow with 2 12" bottoms. One coulter disc is slightly bent and something in the hub is causing it to bind when rotated.
I don't have a manual, yet, but would like to get this fixed for our plow day coming in a couple of weeks.
I pulled the hub bolt and assumed the disc and hub would easily drop out of the yoke. Not the case... Is there a trick to remove the hub assembly from the yoke?
Thank you!
Jason
Mike M
09-17-2007 09:29:01
 Re: 52 Plow coulter in reply to Jason Z in MO, 09-16-2007 18:50:03
Won't it just fall out if you spring the yoke apart some ?
Jason Z in MO
09-17-2007 12:12:20
 Re: 52 Plow coulter in reply to Mike M, 09-17-2007 09:29:01
I tried, a little. Getting bars in between was a little difficult but I didn't try to hard. I didn't want to break the cast yoke.
The yoke would have to spread at least 1/2" to 3/4" to get the clearance. Do you think it would spread that much?
Mike M
09-18-2007 05:22:46
 Re: 52 Plow coulter in reply to Jason Z in MO, 09-17-2007 12:12:20
I don't think a cast yoke will spread very far.
I still don't think you have to unrivet that hub to get it out of the yoke.
Earl - IL
09-16-2007 20:39:23
Take the rivets out of the disc. & slide the blade out.
Jason Z in MO
09-17-2007 08:50:59
 Re: 52 Plow coulter in reply to Earl - IL, 09-16-2007 20:39:23
Earl,
Good advice as usual! I will give it a go tonight! I was hoping I wouldn't have to mess with the rivets but it looks like its the way it has to be done.
Any reason I should replace with rivets or will good bolts with smooth shanks work as well?
Thanks!
Jason
Earl - IL
09-17-2007 09:16:14
 Re: 52 Plow coulter in reply to Jason Z in MO, 09-17-2007 08:50:59
You can use bolts with self locking nuts .Do you need a coulter blade? Earl
Jason Z in MO
09-17-2007 12:21:19
 Re: 52 Plow coulter in reply to Earl - IL, 09-17-2007 09:16:14
Earl,
The blade has decent diameter but I don't know how well I will be able to straighten it. The plow only came with one coulter. A club member has a coulter assembly. I know it has a serrated blade but I don't know the condition yet.
Do you know of a source?
Earl - IL
09-17-2007 12:43:00
 Re: 52 Plow coulter in reply to Jason Z in MO, 09-17-2007 12:21:19
Jason , I have a used notched 14 in. dia. Shoup in Illinois has the 17 in fluted for $27.25 plus shipping. 1-800 - 627-6137.part number is SH 28093. 2in hole 6 bolt 3 1/2 bolt circle. bolt holes are 13/32 That is what I have been putting on.If you have much trash you need large dia. coulters. Earl
GeorgiaHayFarmer
09-17-2007 18:25:13
 Re: 52 Plow coulter in reply to Earl - IL, 09-17-2007 12:43:00
I have a 55 ABH plow that needs 3 coulters. Where might one find a set of 3?
Scott
Earl - IL
09-17-2007 19:06:19
 Re: 52 Plow coulter in reply to GeorgiaHayFarmer, 09-17-2007 18:25:13
Douglas Coates, Used Deere plow parts.563-588-1058.He is in Dubuque,Iowa Call 12 noon or 7pm. in eve.Central time. He is a honest man to do business with. Earl
