4510 Transmission Operation on Hills Losing connection
Wakter Jaeger
09-16-2007 18:36:03
I have sttep hills on my property I bush hog, I purchased a used 4510 on the recomendation of JD salesman who had looked at my terraon. The clutch spring had been jerry rigged and I was having trouble with keeping it on. In the process of finding a way to hold it on I moved the adjstment on the yoke which is attached to the rod attaching to the cam attaching to the clutch pedal. I promptly went down one of my hills and lost contact with the transmission and was free wheelling. I quickly readjusted the yoke to where it had been before, I discovered that the clutch pedal spring was a rigged affair and bought the proper spring. All was fine this spring and using the tractor durring the summer for mostly bucket work. Yesterday I changed the transmission/hydraulic fluid and all filters. This is a used piece of equipment: 625 hours on the machine when I bought it and 675 hours now. The old fluid was dark in color, not filthy and the metal filter screen only had a few small bits of metal. Today I started bush hogging for the fall and going down one of the steep hill sides the tractor was free wheeling once more !! Until The slopes are 3 to 1 or 3.5 to one depending on where you are. I experienced no slipage going up the hills. My question is: how do I know when the yoke is adjusted properly - it obviously controls some key valve.? And secondly how steep is too steep for this tractor?
