D clutch problem
ewh
09-16-2007 16:16:51
I parked my 1935 Model D out back 2 years ago and covered it up. I started it today, but I cant get the clutch to disengage. I took it completely apart, cleaned things and put it back together and it STILL wont disengage! Obviously, I cant drive it now because I cant get it into gear. I sat and looked at it while apart, pulley and all, and I cant even seem to figure out how it works. Any help would be appreciated. Also, when I parked it 2 years ago, it worked fine.
Bob-Wyo
09-16-2007 19:15:32
 Re: D clutch problem in reply to ewh, 09-16-2007 16:16:51
EWH did you pull the clutch driver off so you can get to the last fiber disk behind it? Reason I ask is I replaced mine 2 years ago with new JD disks and 5 days later that inside one was stuck tight and couldn't get the pulley to stop turning to get in gear either. Them new ones have a coating of some kind that needs cleaned off before installing. One other thing if your pulley brake is adjusted to tight if will keep if from disengaging also, but should hear the engine pull down some when you apply some force to the clutch lever..
Bob
ewh
09-16-2007 18:31:31
They are free. I did clean all the gunk out, and the bolts move freely. How much should they move?
Mike M
09-17-2007 05:31:56
 Re: D clutch problem in reply to ewh, 09-16-2007 18:31:31
I don't think they will move much ? as long as they move it should be ok ?
I'd check and make sure the pulley brake isn't binding up too ? And also check the facings mentioned in the above post.
Does your linkage seem to move allright ? does it seem like the fork down inside is moving ? With the engine off and tranny in neutral you should be able to operate it while turning the pulley by hand and see how it all feels. Snapped in it should be tight,snapped out it should turn freely,pull back on handle then pulley brake should grab,if the brake doesn't catch then the pulley will go back to far and tighten up that back facing again.
Mike M
09-16-2007 17:16:09
Check the area in the pulley where the bolts go through as sometimes they get junked up and froze up then your clutch won't work right. If your clucth is all apart you can grab the bolts and they should work freely bach and forth by hand.If they don't get out your favorite penetrant oil.
