Impluse problem on mag on my B
old
09-16-2007 16:15:59
Seems like ever since we had the big rain and flood the impluse on my Bs mag only trips when it wants to trip. Is there an easy fix for this like maybe needing oiled or is it likely to be a bigger problem??
Thanks
John T
09-16-2007 17:05:06
 Re: Impluse problem on mag on my B in reply to old, 09-16-2007 16:15:59
How ya doin my Old friend?? Ive had decent luck simply by removing the mag and air cleaning out the impulse assembly (didnt disassemble it, just insure the nuts tight) and then use light lube lithium grease etc so the dogs extend outward to engage as they should then stick her back on. In cases where misaligned governor bearings cause the impulse drive cup to become too tight against the governor drive you might have to add an extra mag to governor flange gasket if thats a problem.
Take care
John T
old
09-16-2007 17:24:05
 Re: Impluse problem on mag on my B in reply to John T, 09-16-2007 17:05:06
This just happened not long ago. It would start just fine till I had about a foot of water in the shed it was parked in. I then went to start it yesterday and found the impulse wasn't tripping as it should at times and other times it would. I figured after I had it started maybe running it would help but when I tried to start it today it was a no go again. I want to use it to rake hay tomorrow so maybe we will pull start it and then I'll paly with it after the hay is raked
