aluminum pistons vs cast iron pistons
Bill In BC
09-16-2007 14:04:22
I am wondering, are the aluminum after market pistons that are available for the two cylinder tractors, all fuel style or gas style. Is there any difference in the operating characteristics between an engine with aluminum pistons and one with cast iron pistons. I once read somewhere that aluminum pistons make a two cylinder sound different.
Franklin
09-17-2007 02:49:18
 Re: aluminum pistons vs cast iron pistons in reply to Bill In BC, 09-16-2007 14:04:22
I rebuilt the engine on my 49 "B" 13 years ago and used aluminum pistons(.045 over) and haven't had any problems. I don't run the tractor much anymore so this may not be a good indicator.
zwr
09-16-2007 18:29:39
According to my reference book, the coefficient of thermal expansion for Al is about twice that of iron (and steel). I would guess that the Al piston is more demanding of the rings.
Mike M
09-16-2007 17:12:00
Most aftermarket pistons I have seen were for gas. They could be makeing anything today though.
I have noticed that the alum ones speed up quicker and don't lug down as good. Hard to notice unless you have 2 identical models and know which one has what. Never saw a cast iron piston with broken rings. Have seen several alum. ones with broken rings. I'm thinking this is from narrower rings and the side play gets too loose and the rings flex and break. Likely right about this time it's worn enough to be bored out again. I think you can get away with more with cast iron ones.
gurneejoe
09-16-2007 17:11:17
From my understanding, all the aluminum pistons are gas. I"m not sure if you can actually tell the difference in sound or not. One benefit is that they warm up a little faster and maybe a couple of more HP or so if they are stock sizes.
machinery-man
09-17-2007 08:24:23
 Re: aluminum pistons vs cast iron pistons in reply to gurneejoe, 09-16-2007 17:11:17
Have had both and feel the aluminum models lack the torque factor of the cast. I would say the cost factor is the reason for the production of aluminum. The later JD"s used some type alloy rather than aluminum. The upper ring groove always takes a beating whereas the old cast iron never seemed to be a factor. I know bore clearance needs to be about twice the cast iron due to expansion.
