JD 'B' rear wheel cast centers
Mathias NY
09-16-2007 10:00:44
I know that both the 'A' and the 'B' both had 38" rear wheels. I know the axle diamters were different, but were the rims the same? I am looking for a set of cast rim centers for my '49 'B' and my have found a set from an 'A', but I don't know if they will fit. Thanks for the help.
Bob Collins
09-16-2007 13:22:10
 Re: JD 'B' rear wheel cast centers in reply to Mathias NY, 09-16-2007 10:00:44
I believe the cast centers are the same except the "A" used 8 studs to clamp to the rim and the "B" only has 4 of the bosses drilled and tapped. Of course the bolt in hub is different, as you said for the axle size difference. Various width rims could be used. AA3816R is the part number for the casting but I don't think it appears on the part itself.
Mathias NY
09-16-2007 16:34:37
 Re: JD 'B' rear wheel cast centers in reply to Bob Collins, 09-16-2007 13:22:10
As long as the 'B' size hub will bolt in it sounds like I should be all set. Thanks for the help.
