1928 D running rich (update)
WeirdDeere
09-15-2007 22:35:16
I asked some questions about this earlier:
1928 D running rich
Help with take apart spark plugs
An update...
It appears that the problem was just fouled plugs (!@#$$%^^&) Dummy.
The bowl fuel level is right on the line.
Switching plugs cures the problem, and it starts better too (though it didn't seem to start or idle too bad before). Throttles up alot better, only a short puff of black as it picks up RPM, and no hesitation.
BUT, switching plugs doesn't seem to last long AT ALL. Get it started and putting around, it doesn't take long before it acts bad again. I think I've got the carb set as lean as I can get it. I wish I could WORK the tractor...I think that would help...but that's NOT an option. Long story.
I've taken apart and cleaned nearly every plug we had. All OLD Champions: two A25, two X, and a single #33. The two prong #33 seems to be doing the best out of all of them...I have it in the right side now (which I think fouls more often). Wish I could find another!
I might as well ask a question...what should I run for a sparkplug gap? I'm trying .030 right now.
Brandon
Gerald J.
09-16-2007 18:08:16
 Re: 1928 D running rich (update) in reply to WeirdDeere, 09-15-2007 22:35:16
I think with a magneto, I'd close the plug gap down to .022 or .025, no wider.
Gerald J.
two cylinders saves gas
09-16-2007 10:52:05
Did u try a higher octane gas? Right side weak fire is common for old 2 cylinders .
Tom43
09-16-2007 11:21:06
 Re: 1928 D running rich (update) in reply to two cylinders saves gas, 09-16-2007 10:52:05
Why in the world would you advocate high octane gas when the D originally ran on distillate or kerosene which is low octane?
wilamayb
09-16-2007 13:26:10
 Re: 1928 D running rich (update) in reply to Tom43, 09-16-2007 11:21:06
Because higher octane gas burns with less carbon residue. You are right.. D's came out to run distillate, but guess what??? They were made to run at operating temperature and with at least an occasional load which produces enough heat in the combustion chamber to burn the excess carbon off the plugs.
FYI... Kerosene is not even rated with an octane number, but rather a cetane number. To my knowledge I have never seen any type of octane or cetane rating.
Why would you speak in a condescending fashion when you dont know yourself? Want to remove your foot from your mouth yet?
Why at all do we need to put others down?? What is the point? Didnt make you look good at all. Did it? You had us guessing about how smart you were, but then you opened your mouth and removed all doubt.
Just becuase you dont understand it does not mean it's not right.
Just take a chill pill and take the day off.
09-16-2007 14:26:53
 Re: 1928 D running rich (update) in reply to wilamayb, 09-16-2007 13:26:10
Thanks wilamayb for the support. Its quite obvious that a higher octane creates a cleaner much more powerful explosion. I think that old d's bottom end can hold up to that little boost of energy. I run octane booster in all my tractors the plugs come out alittle less black. Kerosene and distillate for christ sake they were burning whatever they could find back then. I guess kerosene was cheaper than gas back in the day.
mjbrown
09-16-2007 17:42:44
 Re: 1928 D running rich (update) in reply to two cylinders saves gas, 09-16-2007 14:26:53
It's my understanding that higher octane gas does not produce more power. It burns slower which reduces detonation in high compression engines. The higher compression of those engines is where the extra power comes from. Unless the '28D has been extensivly modified it is not a high comperssion engine.
The puff of black smoke indicates a too rich mixture at least intermittantly.
WeirdDeere
09-17-2007 11:23:35
 Re: 1928 D running rich (update) in reply to mjbrown, 09-16-2007 17:42:44
I"ll admit, I"ve always been skeptical of running high octane gas in an old all fuel D (or others). It won"t make them more powerful (unless you bump up the compression to match), and I really don"t understand how high octane would burn any cleaner.
I"m not arguing, I just don"t get it. Help?
If I get a chance, I will try it, thought that might not be "til next year?!?! Maybe I"ll try to run it more now that it"s out again...
Brandon
