9 hole hubs for John Deere 50
kpx1
09-15-2007 17:03:24
Did John Deere make 9-hole hubs the model 50? If not, what can I use as a replacement?
Mike Aylward
09-15-2007 17:57:17
 Re: 9 hole hubs for John Deere 50 in reply to kpx1, 09-15-2007 17:03:24
Kpx1, the hub you want was not available from the factory but can be created. You will need a factory dual hub for a 4010 with a 3 1/8" axle. You can then remove the wedges from your cast wheels and insert them into these hubs for a "factory" 9-bolt hub. Do not use a 4020 style hub (3 3/8") as the tapers are different from the earlier style hubs. It can be done. Hope this helps. Mike
Mike M
09-15-2007 17:13:29
I did have a set made by M&W I think ? I don't think Deere had them. Some other brand of tractor may have somthing that works. As long as they have a key and are the right dia. they should work they won't have the wedges but more like a 2 pc. clamp.
