D radiator overflow tube
farmboy169
09-14-2007 19:21:28
Good evening guys. Is the overflow tube on a D radiator suppose to stick into the top tank a little ways. The one on mine is even with the bottom of the top tank, so when I put water in it the water runs out the tube as soon as it gets into the top tank. Thank you.
farmboy169
09-15-2007 06:33:42
 Re: D radiator overflow tube in reply to farmboy169, 09-14-2007 19:21:28
Yeah, I see what you mean, I noticed that this one was plug also. Someone back in the day has shoved what looks like a part of a tree branch into the pipe! Maybe I'll just do the same, plug the pipe and fill it up with water. Do you know why they plugged these back in the day?
CNESLER
09-15-2007 18:26:19
 Re: D radiator overflow tube in reply to farmboy169, 09-15-2007 06:33:42
When the tractor gets warm the water expands and
overflows right onto the fan so that the driver
gets a shower
CNESLER
CNESLER
09-15-2007 04:37:52
The overflow should stick up into the upper
part of the radiator. Most have the hole plugged.
CNESLER
