2020 Oil and hydraulic fill locations?
Kent in KC
09-14-2007 06:19:46
All right, this sounds dumb but I'm being cautious until I get a little more familiar with this tractor. I see a fill port with an aluminum cap that says 'Torq Gard' right at the front of the engine. It looks to be the engine oil fill port. Correct? Where do I check/fill hydraulic fluid?
Thanks again.
Matt Minacci
09-14-2007 06:59:27
 Re: 2020 Oil and hydraulic fill locations? in reply to Kent in KC, 09-14-2007 06:19:46
Yes you are correct with the torq gard. That is your oil fill. To check the hydraulic/trans fluid there is a dip stick located on the right side of the rear axle housing just under the 3pt lever. To add fluid, the cap is located between the top link and the back of your seat. Make sure that any hydraulic fluid that you add is equivalent to John Deere Hyd Guard standard viscosity hydraulic/ trans fluid.
Good luck, Matt
