Fuse or Breakers in Electrical System?
Bob Nelson
09-14-2007 06:11:59
Does a 1020 have fuses or breakers somewhere in the electrical system? This is a curiousity question rather than having any current problem. I don't believe I've ever found a fuse box.
WTW
09-14-2007 12:10:34
 Re: Fuse or Breakers in Electrical System? in reply to Bob Nelson, 09-14-2007 06:11:59
1020 tractors had one circuit breaker fastened to the back side of dash consol near the ignition switch. Never really gave much problem unless you had a short to ground or gasses from the battery ate the wiring ends from it. I have seen some German bulit versions of the 1020 that did have odd looking fuses. DW
Bob
09-14-2007 08:28:53
It's been a LONG time since I've been around one of these tractors, but a quick look at JDPARTS shows a circuit breaker behind the dash panel, Key #2, for ALL serial numbers.
I can't say for sure if that was original, or just with the replacment wiring harnesses.
Third Party Image
msb
09-14-2007 08:08:55
None that I recall.
John T
09-14-2007 07:34:47
Some tractors used fusible wire links even which I really despise lol they muat have been cheaper then a fuse or breaker Im sure of. Of course on the older tractors they figured such small gauge wire (lights etc) itself was sufficent to act as its own fuze.
John T
machinery-man
09-14-2007 07:21:02
I"ve got one and never seen any...I think they were a later addition to tractors....
