Hey pat, H throttle
RobMD
09-13-2007 19:41:29
Wondering what the foot throttle on the "H" was exactly for. Looks like it increases engine speed from 1400 rpm's to 1800 rpm's.
Why didn't Deere just make the regular throttle lever go all the way up to 1800 rpm's, so they wouldn't have to have a foot throttle?
Finally, are the foot throttles compatible with all year "H" tractors?
P Browning
09-13-2007 20:40:38
 Re: Hey pat, H throttle in reply to RobMD, 09-13-2007 19:41:29
Hi Rob -- I start with you last question, "yes" -- the foot throttle control was there from H-1000-up.
The increase in RPM from 1400 to 1800 is for transport only, that means super fast idle to get the tractor from one work location to another in less time. The operator's manual tells us (somewhere) not to put a load on the tractor at this RPM.
Now -- for some opinionated talk! Perhaps the foot throttle control was used instead of a hand control so as to not be real convenient for use of the tractor under a load! Or, perhaps the idea of a foot throttle control was a "late idea" or a sort of an add-on feature! These things did happen as a result of liaison calls between builders and engineers as the prototype tractor was going thru its paces! (PatB)
n29we
09-14-2007 03:58:13
 Re: Hey pat, H throttle in reply to P Browning, 09-13-2007 20:40:38
They did the same thing on the "LI". It bumped up the RPM's a few hundred for getting to work site faster. JimO
DougSr
09-14-2007 05:16:12
 Re: Hey pat, H throttle in reply to n29we, 09-14-2007 03:58:13
Why is that little spring so high? I need one but don't want to pay twenty something bucks for it.
Doug
P Browning
09-14-2007 16:03:00
 Re: Hey pat, H throttle in reply to DougSr, 09-14-2007 05:16:12
This is a problem with so many little things people need. It is a matter of low volume I suppose. Like with a tractor book that sells for $25, one needs to sell nearly half the production run of 750 before you begin to come out of the red! You sure don't do those things for the money.
I had to allow my stock of steps leak on down toward none, and when they are gone, that's it. I refuse to charge what I really need to in order to make selling those worth my time.
On the other hand, there are items out there priced much higher than need be that may make me jump in! The sparkplug shields are a prime example. They were heading on up to $80 a pair! Now there was a case where I knew full well I could get into the market for a short while, bring the price back down to around $60, and then let the stock run out which was my only objective in the first place! I am nearly out of those too! I even made a couple bucks in the process!
Doug, if I get the notion I am being held up for something like that spring, I will take as stroll to my friendly Ace Hdwe store and see if they don't have some spring from which I can make one! So long as it is neat-looking and does the job, go for it! Besides, I don't think the Corect Police are looking into springs these days anyway (hehehe).
Bottom line -- for those of us with more time than money, creativity is the answer to a lot of those little part issues like that spring. (PatB)
