JD 40 clutch
twincreeks
09-13-2007 17:36:04
I have a jd 40 Standard. When I put it in 3rd and 4th gear and try to go up a hill that slopes up gradually the tractor just sits there. The tractor will not choke down. But it will do it in 1st an 2nd gear. Is clutch wore out? Or will adjusting it fix it.
Dave H
09-14-2007 04:45:51
 Re: JD 40 clutch in reply to twincreeks, 09-13-2007 17:36:04
You havn't adjusted the clutch? It should have approx 1 inch free travel on the foot pedal.
By the way, it is when you have no free play that the throw em out bearing remains in contact with the clutch dogs and keeps the clutch from fully clamping down on the clutch disk.
Hayfarmer
09-13-2007 18:37:14
Have you got excessive free pedal on the clutch pedal? If so adjustment may help. I would try int first anyway. Clutch is not hard to replace on these if you have to. If you hang a blade on the 3 point it will probably balance the rear end. Then just slide the front part away using a floor jack.
RobMD
09-13-2007 19:48:51
 Re: JD 40 clutch in reply to Hayfarmer, 09-13-2007 18:37:14
NO WAY.
You'll never do it like that.
