I grease coming out around axle
morse1980
09-13-2007 16:23:53
I have a 1942 JD last year had grease coming out by my axle. Which seal needs replacing? I hate to rip out the back end unless i have to. the tractor is in side most of the year. I was told water could have don it but after a year i would think out with all the gease. thank you for your time to help me with your responces.
P Browning
09-15-2007 06:51:19
 Re: The Story of FELTS SEALS in reply to morse1980, 09-13-2007 16:23:53
Morse -- As you can observe from the two quality posts in response, whether you have a problem or a Big problem depends on whether you are seeing GREASE or DIFFERENTIAL LUBE at the end of the axle housing. Differentiation between grease & oil also identifies the corective action. Oozing grease (to me) says grease pumped in with a grease gun is coming out through the felt washers -- wipe it away and don't over-grease! The presence of oil says a seal is shot, and commands renewal.
The reason I write is to restate the two different missions of a felt washer versus an oil seal; and what it is that wrecks them.
FELT WASHERS are used in lots of places on the tractor, but they will be found only where field dirt and dust could enter a bearing. Their principal purpose is to block entry of grit.
An OIL SEAL, the other hand, is to prevent this lubricating fluid from spilling out onto the ground! They too are used throughout the tractor, but they are not generally exposed to grit from the outside world.
DAMAGE to either seals or felts can be traced to several causes to include sloppy workmanship during installation or build up. However, the most likely cause is bearing wear and lack of preventive maintenance. Deere made wide use of supporting a rotating shaft using a pair of TIMKEN (tapered) roller bearings with a stop for each, one adjustable by use of shims. Adjustment criteria usually was that the bearings would be compressed just to, but short of stopping the shaft from turning freely. This is called 'BEARING LOAD". And if this measure is met, there will be NO RADIAL MOVEMENT of the shaft! It is the radial movement of a shaft not kept in adjustment that kills seals. The result will be noisy operation and (in the case of the final drive,) oil seaping out at the end of the axle housing. Now you have the whole story of felts & seals in one piece! (PatB)
bunghammer
09-13-2007 19:35:04
 Re: I grease coming out around axle in reply to morse1980, 09-13-2007 16:23:53
Is it leaking gear oil or grease? Jack up your side that is leaking and check it for play with a dial indicator for play. If you have play in your axle that will usually ruin the inner seal. Seems like whenever you go to put in a new seal you find alot of other probloms as well. I did both axles in my 60, all new seals, bearings, and outer felts. It was not a cheap job.
Best of luck, bunghammer.
RobMD
09-13-2007 19:29:22
You're either pumping too much in, or your inner axle seals are leaking. More than likely, your inner axle seals are leaking, so you'll have to pull the rear end out. Not a hard job.
