2020 cutting out at high speed
Kent in KC
09-13-2007 14:26:00
Got a 2020, drove it home, about 15 miles. Ran pretty good till a couple miles from the barn, then started cutting out like it was out of gas. Stopped, refueled, still did it. Limped home pulled carb, filter screen was packed with rust. Pulled gas tank, full of crud, steamed it, scrubbed the inside with five pounds of deck screws, flushed again, let it dry two days and sealed it with Red Kote. Let that dry a day and a half. Tank looks great.
Rebuilt the carb, new float needle, etc. put in new fuel filter (the screen built in to the elbow that the fuel line connects to. Blew out the fuel line. Refilled tank with clean fuel.
Replaced air filter. Checked plugs, plug wires, points, condenser, cap and rotor - all look new and properly gapped. Replaced battery. Clicked my heels twice and fired her up. It still does it.
Runs great at lower rpms and if you gently ease the rpms up it will run at high speed. But a quick acceleration to high speed makes her cut out. Vroooom-Uhhhhh hh-Vroooom-Uhhhhh hh.
This is my first Deere. What am I overlooking? Engine is dry, no rain. Inside the distributor cap is dry.
Thanks.
Larry Prather
09-23-2007 19:23:07
 Re: 2020 cutting out at high speed in reply to Kent in KC, 09-13-2007 14:26:00
I have same problem. Tractor runs for about 30-40 minutes like new. After warmed up good it cuts out when put under load. If I shut it off for 10-15 minutes it has full power for 10 minutes or so, then if put under load it cuts out when govenor opens up. New coil, fuel filter, condenser, and plugs and points.
teddy52food
09-14-2007 06:47:46
Your main jet is still partially plugged.
Kent in KC
09-15-2007 06:09:14
 Re: 2020 cutting out at high speed in reply to teddy52food, 09-14-2007 06:47:46
That's what I thought. Tore it all down again and blew it all out, removed the jet, etc. HOwever, it seems the throttle shaft that controls the butterfly is sticking. Can't get it to loosen up so I guess its bent. THink I'm going to get a rebuilt one and see if that fixes it. Also cleaned and lubed the distributor centrifugal weights, still missing. Grr.
Thanks, guys.
msb
09-13-2007 20:26:13
Centrifugal advance system in the distributor probably needs some attention. Take the top off and remove the points /condenser mounting plate. Clean her up and put oil down the top of the shaft.Twist the shaft back and forth to see that it is free and not binding.Clean off any corrosion, rust or other crud on all four of the rotor/tower connections and the rotor itself.New set of points and condenser, set the timing and you are OFF TO THE RACES!
Kent in KC
09-14-2007 06:16:53
 Re: 2020 cutting out at high speed in reply to msb, 09-13-2007 20:26:13
Thanks!
Kent in KC
09-13-2007 14:30:32
 PSS: Marvel Schebler carburetor in reply to Kent in KC, 09-13-2007 14:26:00
TSX-905SL
Kent in KC
09-13-2007 14:26:53
 PS: its a gas engine in reply to Kent in KC, 09-13-2007 14:26:00
not a diesel
