Cylinder honing, '50A
njs
09-13-2007 06:45:30
Cyl. block is out and ready to be honed. There is a ridge near the end of the stroke that I have no way of removing. Do I stay away from it with the honing tool or ride over it? (Estimating ridge step runs zero to .015").
johns48jdb
09-13-2007 15:05:00
 Re: Cylinder honing, '50A in reply to njs, 09-13-2007 06:45:30
rent you a ridge reammer and cut the ridge out. every time the ring comes up and tries to ride up into the beveled place your going to make it flex. it will break your rings. a tool and die grinder is not the way to go.
teddy52food
09-13-2007 10:15:29
If you take the block out and put 2 gaskets between the block and crankcase, you don't have to worry about the ridge.
njs
09-13-2007 10:35:08
 Re: Cylinder honing, '50A in reply to teddy52food, 09-13-2007 10:15:29
Another $18 but not a bad suggestion. Thanks.
Mike M
09-13-2007 06:57:31
If you are at .015" wear then your block should be bored. But it does depend on how much and how hard you plan on running it ? I like to use an inside mic and not guess.
You can get that ridge out or blended down some with a Dremal or a die grinder. Most normal ridge reamers won't go down in that far.
njs
09-13-2007 07:01:06
 Re: Cylinder honing, '50A in reply to Mike M, 09-13-2007 06:57:31
Thank you Mike. I had thought of doing that so it would not chip off the end of the stones. Just needed your prospective, not relying on my own only.
machinery-man
09-13-2007 08:12:04
 Re: Cylinder honing, '50A in reply to njs, 09-13-2007 07:01:06
I've always used a die grinder but be careful, you're only trying to bevel the step down where the new rings want impact. Most of the wear is at the end of the stroke top side where the knuckling of the piston occurs. It obviously is out of wear tolerences but a new set of rings and since you're not farming with it, should bring it back to usable shape....I've done it several times before...of course if you want it book specs have it bored new pistons...but if you go that route be sure your machinist knows how much clearance is needed depending on pistons. I had one bored and it was the smoothest running engine I've seen but had less power as the machinist got the specs too close.
njs
09-13-2007 09:50:08
 Re: Cylinder honing, '50A in reply to machinery-man, 09-13-2007 08:12:04
I can always count on you and MikeM to help. Do you guys work? (which is where I am now) You always seem "there"!
Mike M
09-13-2007 10:11:24
 Re: Cylinder honing, '50A in reply to njs, 09-13-2007 09:50:08
I'm mostly playing on here at work as things are slow right now. That's why alot of times my posts are too short and may not make enough sense as I got to try to hide from the boss ! LOL
njs
09-13-2007 10:25:41
 Re: Cylinder honing, '50A in reply to Mike M, 09-13-2007 10:11:24
Another ditto, 2xLOL
