4050 Timing
turklilley
09-13-2007 04:06:30
It seems my 4050 has fuel pump timing problems. It was was starting to smoke out the exhaust, then later it started to miss at higher rpms, and losing power. The timing lines in the injector pump window don't line up at #1 TDC. Do the Stanadyne pumps slip time?
rexhellwig
09-13-2007 18:40:28
 Re: 4050 Timing in reply to turklilley, 09-13-2007 04:06:30
"Do the Stanadyne pumps slip time?"
Not unless the pump mounting nuts or the pump gear bolts are loose.
Make sure you are checking the timing with the engine turning in normal rotation. As the timing pin enters the flywheel, the timing marks behind the window should be aligned. If they are...the next step would be to get someone to check high speed timing with a transparent timing window. {the timing is supposed to advance when revved up, see tech manual}
If all this is OK, when was the last time you checked the valve lift and lash?
