Hydraulic problems
Bob in GA
09-12-2007 15:02:55
I have been trying to mount my front end loader today and can not get the lift arms to retract. They are completely extended and were left this way per directions on how to dismount them. Tried using a different hydraulic circuit and same results. You can see the lines vibrate when I try to extend them but the cylinders don't move. Any suggestions will be appreciated.
MPK
09-12-2007 20:08:10
 Re: Hydraulic problems in reply to Bob in GA, 09-12-2007 15:02:55
It might just have pressure built up that needs to be released in order for the couplers to open. Sometimes I would tap the ball on the end of the coupler to release some oil, but you can get sprayed with oil that way. That is sometimes a problem to get around for which I don't have a good answer.
Jonathan in MA
09-12-2007 16:38:38
I'm assuming there are quick couplers involved in the process... I've seen one side of a coupler get stuck and not allow flow in one direction when coupled.. I'd check all couplers involved and make sure the check-ball or plunger or whatever style you have move freely. If it worked ok when it was parked, its probably something simple like that..
