630 fuel shut off
Greg A
09-12-2007 05:30:15
Over the last 10 years I have replaced the diaphragms in the auto fuel shut off 3 times. The tractor sits for long periods at a time and I am thinking that these diaphragms are drying up and failing. I was wondering if anyone has added or found a manual shutoof that can be installed on the sediment bowl and the fuel line modified to attach to the shutoff.
Mike M
09-12-2007 06:07:33
 Re: 630 fuel shut off in reply to Greg A, 09-12-2007 05:30:15
Couldn't you just put on one from something like a late A model ?
If your tractor sits for long times drain out the gas and put some kerosene in the tank and manually push down the valve and let it flow through and into the carb. Have the carb. drain open until you see/smell mostly kerosene come out. Then just reverse the process and pour gas in it when you do get it out for a run. I have done this for several years now and it is the best way I have found for seldom used gas tractors.
Oh there is some little tricks to those auto shutoffs that may help them. You have to make sure the center section is in the proper direction as one side is dished more than the other. I put the deeper dish to the top so the diaphram has more travel and put in all new diaphrams and start all the screws then push down the plunger and hold it while you tighten the screws. This probabaly lets them have enough prestretch ? This is how Briggs & Stratton says to do their diaphrams so I do it on the JD's too.
John T
09-12-2007 06:24:51
 Re: 630 fuel shut off in reply to Mike M, 09-12-2007 06:07:33
Mike, Good point regarding proper instalaltion of that center section as they fit EITHER way and look about the same HOWEVER as you noted and I found out by "expereince" they dont work if 180 out cuz the top manual plunger cant push down to open the valve grrrrr rrrrr That concave/convex makes it deeper or shallower on one side or the other fer sure
When I take em apart now I keep that section teh right side up and dont let it get turned before re installation lol
John T
Mike M
09-12-2007 06:26:18
 Re: 630 fuel shut off in reply to John T, 09-12-2007 06:24:51
I just mark them before takeing them apart. Providing they were right before. But this also lets you get the oil port in the right spots.
motorstuff
09-12-2007 20:47:31
 Re: 630 fuel shut off in reply to Mike M, 09-12-2007 06:26:18
Good comments. I have my shutoff and carb apart in my garage, and the rest of the traotor is 100 miles away. What is the proper location of the oil port comparted to the gas inlet?
thanks,
Mike M
09-13-2007 04:52:48
 Re: 630 fuel shut off in reply to motorstuff, 09-12-2007 20:47:31
I have no idea as I mark mine before taking them apart. I don't have a 630 model either to go look at. I'm not sure if all models are all in the same spot either ?
Hopefully someone has one handy to look at and can help out with that position.
