B Lopes and Back Fires
MB in NE
09-11-2007 22:55:16
My neighbor has a B that he has rebuilt the carb and replaced the governor on. Now, the motor rev"s up and down and back fires. If you hold the gov. it stops lopeing and back fireing but runs rough and the gov. fights you. Any Ideas? Thank You
P Browning
09-14-2007 06:57:00
 Re: B Lopes and Back Fires in reply to MB in NE, 09-11-2007 22:55:16
Hi There -- As johns48jdb was telling you, go to the JD-H Restoration Site. Once there, look at the drop-downs under ARTICLES (1 or 2), Start first with CARBURETORS. On page 9 of that piece you will find a no-wrench test for your carb. You can test the IDLE side separate from the LOAD side for blocked passage ways. The IDLE path for fuel/air mix getting to the engine has five segments, and any one stopped up will make the engine run in a hunting or loping manner because it is drawing its sustaining fuel from the LOAD side -- the governor driving the carb open to fetch another gulp of fuel!
Once you have that result, post back. We go from there. (PatB)
HAPPY DEERE
09-12-2007 03:36:35
sounds like a clogged idle port in the carb as for the backfiring try checking your timing
johns48jdb
09-12-2007 02:23:16
sounds like he didn"t get it timed back right for starters. go to JDHPubs and read up on timing and cleaning carbs. p browning will help you out when he sees this post.
