change hydraulic / transmission oil 4020
john young
09-11-2007 19:54:45
All,
just got a 66 4020. though i didnt (still dont) know much about them I"m learning...a little.
this is likely to sound like a stupid question, but with a synchro shift...the transmission and hydraulic oil is the same, right?
How do you change and where is the filter located? Is there any good online reference material for mtce of a 4020? I have a shop manual, but it doesnt cover basic stuff like this.
thanks,
bighead
09-11-2007 20:47:36
 Re: change hydraulic / transmission oil 4020 in reply to john young, 09-11-2007 19:54:45
If the drain sticks, hit it with a big hammer. That will smash the seal washer just a hair and loosen the plug right up.
msb
09-11-2007 20:19:13
Same oil. Transmission case serves as the reservoir.Dry capacity is 13 gallons , so expect to get at least 12 gallons once you pull the plug.Best to have 3 -5 gallon buckets handy. Drain plug is 1 1/4 " plug under the transmission. Filter is on the left side of the transmision case. The bolt in the filter cover takes a 3/4" wrench. If you are not sure about the service history then I would pull the suction screen. Its a plug right behind the hydraulic filter cover. Could take a 1/2" breaker bar, a large Crescent wrench or a large Allen wrench to remove the plug,depending on what Deere was using at the time. The screen simply pulls out.
