john deere model m rock shaft lift not working
a c smith
09-11-2007 19:36:13
i need help solving the problem i have with my john deere model m tractor arms not lifting,is there a rebuild kit available for whatever valves and parts needed to replace the parts that may possibly be worn out? again it was lifting and then would not go up anymore.i replaced the original pump with another used one which seems to be pumping when i loosen the smaller line at the valve body. thank you
John Moore
09-11-2007 19:54:04
 Re: john deere model m rock shaft lift not working in reply to a c smith, 09-11-2007 19:36:13
AC,
I rebuilt the Touch-O-Matic on an M about six months ago. Was pretty easy to do even for a novice like me. Deere had all the parts. Good Luck. John
a c smith
09-12-2007 18:12:25
 Re: john deere model m rock shaft lift not working in reply to John Moore, 09-11-2007 19:54:04
thanks for the response, i guess i'll tear it down and see what everything looks like.can you tell me what parts that you needed to get yours up and going again.
John Moore
09-15-2007 17:04:02
 Re: john deere model m rock shaft lift not working in reply to a c smith, 09-12-2007 18:12:25
AC, Sorry so long in responding. Got real lucky. I was able to clean every and it worked fine. Only had to use the gaskets. Best Wishes. John
40 420 430
09-12-2007 19:58:56
you might try to pull the plugs on the side of the unit there is a round keeper in it use a 3/8 bolt to work the plug out ther are check valves in there slip them out ,ther might be trash in there and you might try flushing the system before you take it down your manaul tells the steps there not a lot to them to just stop working ,trash, pump ,low fluid let us know
