Gauges and Serial Numbers
RonRod
09-11-2007 18:34:02
I have a 1952 B which has black faced gauges yet every thing I see by repro. gauge sellers says lettered tractors all had white face gauges. Would anyone know if B"s were shipped with black gauges and at which s/n they started. Also do the B"s and A"s take basically the same gauge i.e. diameter.
Thanks as always
Ron
Stan - Florida
09-13-2007 07:18:06
 Re: Gauges and Serial Numbers in reply to RonRod, 09-11-2007 18:34:02
Just out of curiosity, what is the serial number of your 'B'?
Stan
RonRod
09-13-2007 07:14:49
I'm sure the black face gauges are original because I've owned the tractor since 1975 or therabouts and they were not new when I bought it.
I'm sure the previous owner didn't change them all out from white. I'll stay with black and thanks for the input.
Ron
RonRod
09-13-2007 07:46:24
 Re: Gauges and Serial Numbers in reply to RonRod, 09-13-2007 07:14:49
Unfortunately I don't know the S/N as the plate got rusted after 20 years sitting in a field. It's become a restoration project only recently.It's after 306600 as it has a factory insalled water pump and is a BW shipped to either Quebec, Canada or Vermont. I presume due to the black gauges it must be among the last ones built. I may bring the S/N tag to someone who can decipher it somehow. Any thoughts?
Ron
CLW
09-13-2007 15:04:51
 Re: Gauges and Serial Numbers in reply to RonRod, 09-13-2007 07:46:24
Just so you know, when the water pump was factory installed Deere offered it as a retrofit also for any late styled B. The assembly was part number AB4267R. So you could find a 47 B with what looks like a factory water pump on it.
Stan - Florida
09-12-2007 05:10:19
According to a J.R. Hobbs article in the April 1997 issue of Green Magazine, "Gauges were of the 'white face' variety until serial number 306600 when it appears that 'black face' gauges began to be phased into production".
Stan
Melbourne, FL
Bob Collins
09-13-2007 05:27:31
 Re: Gauges and Serial Numbers in reply to Stan - Florida, 09-12-2007 05:10:19
Stan, You are right, I stand corrected, but with only about 1100 "B" tractors built after they started phasing in black gauges, the chances are way in favor of white faces.
Stan - Florida
09-13-2007 06:11:01
 Re: Gauges and Serial Numbers in reply to Bob Collins, 09-13-2007 05:27:31
Bob,
You're right about the odds of him having black-face gauges are pretty slim.
bunghammer
09-11-2007 20:03:35
Some of the later model letter tractors got what ever was left laying in the bin some white some black, some even mixed together. A guy that used to work at waterloo, said somtimes the decals even got placed different from side to side on the hoods.
deere diesel
09-11-2007 19:01:25
i was told some of the 1952 models had black gauges, i have a one owner 1952 G bought from the neighbor with black gauges. i would keep them black if it was mine
Bob Collins
09-11-2007 18:55:08
The diameter of gauges is pretty well standardized, I think it is 2 1/8", so yes "A" and "B" gauges are about the same. The temp gauge may have a different length tube. It seems to be well accepted that B tractors all came from John Deere with white face gauges.
