3020 won't run
mike dean
09-11-2007 17:21:23
i have a early 3020 that will run like a top and without warning will start to sputter and back fire till it wont start anymore. after several carb cleaning, it will start and run great for 2 months, then back to no starting. i dont know what im doing to get it running or why it fails again. this is the fourth time its gone down. it doesnt matter what time of year, hot or cold, and it is a gas. any ideas?
mike dean
09-12-2007 17:10:42
 Re: 3020 won't run in reply to mike dean, 09-11-2007 17:21:23
a new condenser and i'm back in business. thanks for the help.
Larry in WNY
09-12-2007 09:16:10
I have a 1968 JD 3020 gas. First thing I did was add electronic ignition due to problems running then rebuilt the carb. and still had the same problems. Then we noticed whenever the gas tank was low it started to run worse. The fuel pump needed to be replaced. It would pump just enough and gravity feed to run good until the tank got low. Check your carb. bowl next time it won't run. If it's empty then maybe it's the fuel pump.
Larry
Gerald J.
09-12-2007 08:13:08
On my 4020 that came from a Scotchtap in the ignition circuit when the coil dropping resistor in the wiring or the ignition switch was replaced by a ceramic block next to the coil. It would fire fine while cranking, but not run. So I hot wired it for the day of hay raking and removed the Scotchtap from the circuit and have had no more great ignition failures.
Once in a while, points will fail to close because of lack of lubrication. Their pivot shaft can take a quarter drop of oil a year.
Coils fail after a heating period and recover more often than condensers. Condenser failure for me is most often permanent.
Be sure the coil has that resistor, else a new coil (and it takes a 6 volt coil because of the series resistor which is shorted by the starter solenoid), won't give good life or good starting.
Gerald J.
fixerupper
09-11-2007 18:23:42
Maybe the condenser? The condensers we use today don't last nearly as long as the ones from years ago. My 630 started playing the exact same game with me that your 3020 is doing with you, and after I changed the condenser the problem was cured. Now when it starts acting up, which is usually about every two years, a quick condenser change clears it up. Like Wilamaybe said, the coil can act the same way. Jim
mike dean
09-11-2007 18:52:31
 Re: 3020 won't run in reply to fixerupper, 09-11-2007 18:23:42
It has'nt had the coil or condenser replaced for quite awhile now, I will change both and post the results. thanks
wilamayb
09-11-2007 17:43:40
Mike,
Sometimes ignition coils can exhibit these symptoms. They cure themselves when they cool down, but act up again while warm. Have you ever checked to see if you have fire at the plugs when it dies and wont start? You might try next time.
mike dean
09-11-2007 18:18:49
 Re: 3020 won't run in reply to wilamayb, 09-11-2007 17:43:40
I thought it might be the coil, but seems to be getting spark, I can get it running, when its bad, but not good enough to drive. too much throttle will kill it again. thanks for the help.
wilamayb
09-12-2007 04:30:24
 Re: 3020 won't run in reply to mike dean, 09-11-2007 18:18:49
If too much throttle kills it then it may be gas starvation. When It dies next time pull the drain on the carb bowl quickly to see if you have limited gas flow.
You'll find it one way or another!
Rick Trojacek
09-11-2007 17:40:47
Sounds like an ignition problem, not fuel. I had a 3010 that had similar symptoms several years ago. I finally installed an MSD ignition from my race car. This is overkill, but it sure worked.
