730 diesel troubleshooting
gg in texas
09-11-2007 13:24:41
just got a 730 tractor need help power steering does not work but full of fluid also changed fuel filters and put in new fuel but still stalls when you drive it around fuel in glass bowl looks aireated, do not have amanual yet thanks
msb
09-11-2007 20:56:57
 Re: 730 diesel troubleshooting in reply to gg in texas, 09-11-2007 13:24:41
Hardest tractor in the world to get all the air bled out.Just keep bleeding the filters and the take the return line lose and bleed it there.If it has the upgraded (large)check valve on top of the pump cover, take it apart and bleed it there.Have had some that I bled for half a day before I got all the air out .
mjbrown
09-11-2007 16:24:31
If it stalled because of air in the line you would not be able to restart so it must have a stoppage or something mis adjusted could be moving the rack to the cut off position. Yep you need a book.
