1944 B Idle issue/ DLTX-34
J_J_M
09-11-2007 08:07:52
My 44 B is slowly coming back to life but I have an issue with throttling up the tractor. It has a DLTX-34 that has recently been cleaned and had all new gaskets put in it. The tractor idles perfect and will sit and hold a nice slow steady beat. I can start to throttle up the tractor and it will pick up some speed until about 1/8 throttle, at this point it starts to miss. If I give it any more throttle it just dies. If I pull the throttle back quick I can keep it running once in a while. If I continue to back out the idle screw while throttling up I can get it to run at about 1/2 to 3/4 throttle if the idle screw is 6-7 turns out.
Any help would be greatly appreciated. I'm guessing it's a blocked passage somewhere but I'm not 100% sure about that and I don't even know which passage to look for. Thanks in advance.
P Browning
09-12-2007 19:59:12
 Re: 1944 B Idle issue/ DLTX-34 in reply to J_J_M, 09-11-2007 08:07:52
J_J_M -- There has been no word for a while.
Please make a "how goes-it" post to let us know if all is well, or if some other issues have surfaced for you. (PatB)
P Browning
09-11-2007 10:08:52
Go to the JD-H Restoration Site and under ARTICLES, select CARBURETORS. Once there, scroll on down to page 9 where you will find a no-wrench test for your carburetor to tell you if you have a blocked passageway, and which one it is.
The JD carburetor will sustain the engine either through the IDLE side or the LOAD side. From what you describe, it would appear the engine cannot draw fuel through the LOAD side. LOAD fuel is not needed to start and is not needed for idling. But in order to accelerate the engine, LOAD is needed, and this sounds like where you are in trouble.
If the lOAD side is blocked, you must remove the carburetor, take it apart to where you can remove the fuel nozzle and clean the accumulated rust out of the accelerating well into which the nozzle fits.
The piece I sent you to (above) has a theory section and I encourage you to take the time needed to read and understand the pages -- it's not that long.
Getting the fuel nozzle out can be a challenge. If you want some guidance on that one, e-mail me and I will return with an excerpt from the JD-H Carb Overhaul Manual. (PatB)
Mike M
09-11-2007 09:51:23
Have you tried opening up the load needle ???
John T
09-11-2007 09:49:27
JJ, You speak of having the idle screw out 6 to 7 turns but two is more like a normal adjustment. WHAT HAVE YOU TRIED CONCERNING THE LOAD NEEDLE SETTING????? I start with mine around 1 turn out n fine tune adjust from there. Open it n see what happens !!!!! !!!!!
When it was "cleaned" was the main center vertical brass nozzle removed and it n the bore and all its lil side holes well cleaned???
In addition to many of the other "passages" theres one down in the bottom of the bowl area where the load needle screws down into that has to be clean n open, WAS IT CLEANED OUT????
Have any idea where the float level is at?? It may need adjusted higher. If you remove the carb bowls bottom drain cock/plug n replace it with a hose barb fitting n install a clear plastic hose you can elevate it above the bowl level n observe at what level the gas rises to MAYBE THE FLOAT LEVEL IS TOO LOW
If all else above is okay you still need good gas flow from the tank into the carbs bowl. Open the carb bowls bottom drain cock plug n turn the gas on and insure a good steady stream of gas approx 1/16 inch or so flows contimually at least a minute or to to insure good gas flow to keep the bowl full.
Try to adjust the load needle,,,,,Insure good gas flow to the carb to keep the bowl full,,,,, ,,Check the float level,,,,, ,,If shes still gas starved insure the passage at the bottom where the load needle seats down into is clear,,,,, ,,,Insure the main center vertical brass nozzle is cleaned out.
PS when she cuts out its NOT blowing black smoke from over rich running is it????? If so lean the load needle setting and insure the choke butterfly plate is staying open and make sure the air cleaner isnt clogged up
John T
J_J_M
09-11-2007 11:12:30
 Re: 1944 B Idle issue/ DLTX-34 in reply to John T, 09-11-2007 09:49:27
Thanks for all the quick responses. Here's a little more background: I did put a new nozzle in the carb. Gas flows out the drain cock in a strong steady stream. I checked float height when sitting still on level ground and when idling and both were perfect. At idle the Idle needle is 1 3/4 turns out and it runs perfect. I've tried the load needle at 1, 2, 3 turns out, I guess I will try a few more turns and see where that goes.
P Browning
09-11-2007 11:30:06
 Re: 1944 B Idle issue/ DLTX-34 in reply to J_J_M, 09-11-2007 11:12:30
For some reason -- you aren't drawing LOAD fuel.
Is there any chance you forgot to install the nozzle spring when installing the bowl? The spsring holds the fuel nozzle up into the venturi of the carb so LOAD fuel can be drawn.
Run the LOAD & IDLE passageway test and you will learn in a hurry -- if the fuel nozzle has dropped down a little because the spring isn't there, the engine will act as if the LOAD passageway is blocked. (PatB)
J_J_M
09-11-2007 11:30:06
Forgot to mention that when I throttle up it's not smoking black. I can get it to throttle up a little higher and stay running by manually closing the choke half way. So that combined with turning the idle needle out to get it to throttle up higher lead me to believe it's leaning out and starving for fuel as the RPM goes higher. But I'm no mechanic so it's all just guessing at this point.
P Browning
09-11-2007 11:32:52
 Re: 1944 B Idle issue/ DLTX-34 in reply to J_J_M, 09-11-2007 11:30:06
Go get 'em tiger -- you are close! We are pulling for you!! BTW, between 3/4 & 1 turn out is all you should need on LOAD. (PatB)
Mike M
09-11-2007 12:11:07
 Re: 1944 B Idle issue/ DLTX-34 in reply to P Browning, 09-11-2007 11:32:52
Pat; I like your words of encouragement !!!
I think you are so right that he is close. Another time off with the carb. back at the bench for close inspection is a must. This is a critical point in the learning process for him. If he doesn't get discouraged,keeps his head on straight and figures this out then from now on he will be well on the way to getting them the first time.
I remember my first troubled carb. I may of had it off 2 or 3 times ? until I got that darned "secret" passage found and unplugged !
John T
09-11-2007 11:27:23
If that dont do the trick (1 or so out on load needle ought to work) then Id wonder about the lil port/passage where the load needle screws down into n seats cuz its through there she draws in gas n maybe its clogged up???
John T
J_J_M
09-17-2007 07:19:41
 Re: 1944 B Idle issue/ DLTX-34 in reply to John T, 09-11-2007 11:27:23
The Load needle passage wasn't completely obstructed but there was a partial block. I took the carb apart and took out the Load needle and blew into where the needle enters the side of the post. I could get a little air to flow through but I had to blow with all my might and my cheeks looked like Louis Armstrong's when he's playing his trumpet. I took a small drill bit and cleaned out the needle seat and nothing came out. I took the screw out of the side of the post and took a slightly bigger drill bit and after a little twisting a big ball of crud and sand came out. I put my lips back on the outside of the post and blew and air flowed through much, much easier. I'll be putting the carb back on Wednesday night and hopefully I'll be up and running. I'll let everyone know the results. Thanks for all the great help.
J_J_M
09-20-2007 13:23:38
 Re: 1944 B Idle issue/ DLTX-34 in reply to J_J_M, 09-17-2007 07:19:41
I put the carb back on and the old B runs like a top. The partial clog on the load side was the culprit. Thanks for all the help.
36 coupe
09-21-2007 03:38:46
 Re: 1944 B Idle issue/ DLTX-34 in reply to J_J_M, 09-20-2007 13:23:38
I had trouble with a surging idle and found some fuzzy material in the idle passages.Cleaned it out ,now the H idles fine.I keep a spare set of spark plugs soaking in a covered jar of lacquer thinner.Gas fouling is a problem at times, a swap of plugs will keep the tractor running.
