1953 JD 40 Standard Brakes
KY Dave
09-10-2007 09:17:05
Grease is leaking from the hole where you ajust the brakes.Where could this be coming from and what do i need to do to fix it?
Maark
09-10-2007 15:16:20
 Re: 1953 JD 40 Standard Brakes in reply to KY Dave, 09-10-2007 09:17:05
Axle seal leaking. you will need to remove the fender and final drive on that side to get to the seal.
jCarroll
09-13-2007 19:51:45
 Re: 1953 JD 40 Standard Brakes in reply to Maark, 09-10-2007 15:16:20
Reface the brake discs while you're in there - they are probably oil soaked anyway.
And clean the hole that is supposed to let that oil out of the housing before it gets to the brakes.
