JOHN DEERE LA TIMING
FREDDIE P
01-24-2000 18:22:07
I HAVE A JOHN DEERE LA I NEED SOME INFO ON HOW TO GET IT TIMMED UP PROPERLY.
RonMC
01-24-2000 23:33:21
 Re: JOHN DEERE LA TIMING in reply to FREDDIE P, 01-24-2000 18:22:07
Freddie, I assume you mean ignition timing ? I think they are TDC, so pull the plugs, then turn the engine over slow by hand to TDC on compression - air should be felt pushing a finger out the front plug hole, then line up your flywheel TDC mark. Loosen the dist bolt, remove cap and rotor. Watch the points as you rotate the dist. Put a test light on the dist wire, and slowly rotate the dist to the point where the ign points just open (test light will come on) - (it will be off when points are closed). Tighten the dist down right at this point and you should be right. The spark happens when the points open, so that is the place to have it. This is an old automotive procedure, but will work on any point ignition. Hope this helps, RonMC
