4020 shift arms
alan king
09-09-2007 10:53:59
Need upper and lower shift arms. The 2 arms located to the right side of tranny that shifts it to hi lo range and shifts the gears.
Bison
09-09-2007 18:59:21
 Re: 4020 shift arms in reply to alan king, 09-09-2007 10:53:59
new ones are 250 to 280 a piece. used ones are usually worn too.
you can rebuild them too if you have acces to a lathe, braze the tabs up with copper or brass and turn them down to specs in the lathe.
i have built a fixture that let you clamp the shifters to a drill press table,then mount the table in the lathe chuck. did 2 forks last week out of a 3010.
