JD 4400 combine
darrellr
10-31-2003 12:18:43
Friend has a 4400 ,he bought it with a bean header on it.He got a used corn header yesterday. After he used it for a bit the pump that supplies oil to the bean header went out. Question is,do you have to do something with the hydraulic lines when you go from one header to the corn header?
darrellr
11-03-2003 12:25:48
 Re: JD 4400 combine in reply to darrellr, 10-31-2003 12:18:43
Mark.
You were right.I thought that was what needed done...Thanks
Tyler-MO
11-01-2003 09:45:27
I would strongly recommend getting an owners manual for the machine as it will be necessary for making various adjustments and servicing procedures. You can obtain if from your friendly John Deere dealer for around $45. GOOD LUCK
TYLER-MO
Mark
10-31-2003 13:36:51
You will need to connect the two big oil lines together so that the oil will circulate and not get hot. probably what caused the pump to go out.
