41 B Govenor control problem
B Owner
09-07-2007 06:41:10
Hello,
After overhauling the carb and replacing the govenor "speed Change Spring" with a brand new one from Deere ($47.00), it will not govern the speed of the engine. It wants run wide open, and not govern the speed back when you move the throttle lever. We have tried to adjust the linkage rod to no avail.
Could there be something wrong in the govenor housing, weights? My parts book doesn't show any springs inside the governor housing.
Thanks in advance.
B Owner
Mike M
09-07-2007 07:10:06
 Re: 41 B Govenor control problem in reply to B Owner, 09-07-2007 06:41:10
Time to go into the governor. First maybe make sure you have the set screw that holds the arm and spring to the shaft in the notch for it.
