1936 B wheels
MTC
09-06-2007 17:49:26
OK guys-question I have a 1936 B with 10 spline axle.My wheels are shot.My 10 spline hubs I can unbolt from the wheel.Can I bolt them on a 12 spline wheel if I cut the center out and bolt these on?Thanks much,Mike
Duane Larson
09-06-2007 19:09:03
 Re: 1936 B wheels in reply to MTC, 09-06-2007 17:49:26
Mike,
It sounds like you have wheels with a bolt-in hub - hub casting number B2187R and wheel JD1270R. Deere went to bolt-in hubs around 1945 because of hub breakage problems. What is wrong with your JD1270R wheel - if the rim is bad you might contact Detwiler Tractor 715-659-4525 - they may be able to replace your rim. Otherwise you would be removing (ie, cutting out) the 12 spline hub from a styled B with a cast-in hub, and drilling holes in the remainder of the hub to bolt in your 10 spline hub. While that would work, it would destroy 12 spline cast-in hub wheels which have value. JD1270R wheels, which have the 6.00Sx36" rim, are not that hard to find. To avoid destroying a good wheel I would either try Detwiler, or to find a good JD1270R wheel. Another possibility would be to go to round spoke rears (like they came with originally) and sell your 10 spline bolt-in hubs (which also have value). But those are only suggestions - they are your wheels.
MTC
09-06-2007 19:23:30
 Re: 1936 B wheels in reply to Duane Larson, 09-06-2007 19:09:03
Duane-thanks for the advice.I have found a set of steel wheels from a unstyled John Deere B.They are 12 spline and would like to put them on my 1936 B using my 10 spline hubs.There already are holes in the steel 12 spline axle wheels.My question is will my 10 spline hubs line up to the holes in the 12 spline wheel?Thanks much,Mike
Duane Larson
09-06-2007 19:56:55
 Re: 1936 B wheels in reply to MTC, 09-06-2007 19:23:30
Mike,
Yes, 10 spline B steel wheels (both flat and skeleton) were available for B2186R bolt-in hubs and B2097R hub clamps. If the steel wheel has a sort of triangular shaped hole in the center and some bolt holes, all should line up (unless you have a hub meant for a pressed steel wheel - that won't work). The casting number JD1265R should be on the "inside" of the hub on the bolt plate.
What often happens is that a wheel with a cast in hub breaks an ear or two, so the remainder of the splined material is cut out, and holes drilled to accomodate a bolt in hub.
MTC
09-06-2007 19:59:27
 Re: 1936 B wheels in reply to Duane Larson, 09-06-2007 19:56:55
THANKS
