'50 A Rollomatic removal
njs
09-05-2007 18:49:21
The picture shows--possibly--that the unit might drop down/off if I remove 4 screws that look like they attach it to the steering shaft plate. I do not want to have to raise it enough to get the shaft out. Am I dreaming? I loosened the 4 screws and thumped the unit with a 4x4 but it did not drop down.
Pete in MD
09-06-2007 07:01:18
 Re: '50 A Rollomatic removal in reply to njs, 09-05-2007 18:49:21
If you do have a split pedistal you can put a wide-front on it. Look in the parts catalog, PC675, if you have one.
RobMD
09-05-2007 18:53:17
Split pedestals have the rollomatic held to the plate with 4 bolts. Take the bolts all the way out and get something like a 2x4 lever to push it off. Don't let the rollomatic fall to the floor.
njs
09-05-2007 19:01:42
 Re: '50 A Rollomatic removal in reply to RobMD, 09-05-2007 18:53:17
Split pedestal means---? I know that I would be unable to put a wide front end on it due to it's design.
RobMD
09-05-2007 19:06:30
 Re: '50 A Rollomatic removal in reply to njs, 09-05-2007 19:01:42
split pedestal means that the rollomatic will come off even with the underside of the tractor when you take the four bolts out.
A NON-split pedestal requires that you take the steering sector gear bolt out and remove the whole shaft and rollomatic as one unit.
Got a parts book? you can see both versions of the front end.
njs
09-05-2007 19:21:15
 Re: '50 A Rollomatic removal in reply to RobMD, 09-05-2007 19:06:30
RobMD, you made my evening. Thanks!
