JD 510
atk_nut
09-05-2007 15:52:59
Hello,
I have a 69 JD 510 tractor with hydraulic problems. 1st, the front pump seems like it is not getting any fluid. (Yes, I checked the fluid.) How does the feed system work? I'm reading different things about rear pumps and filters etc. Where can I check for blockages?
2nd thing, the fluid for the 3point is disappearing. I read something about a plastic tank that may be cracked? Can this be related to the front pump problem?
Any help would be appreciated.
R. John Johnson
09-05-2007 19:42:06
 Re: JD 510 in reply to atk_nut, 09-05-2007 15:52:59
The 510 is a whole different design than the North American designed and built tractors. It does NOT use a common fluid for hydraulics and transmission. The front pump is NOT fed by the transmission pump. The system is an open center, NOT closed center. The pump up front is fed by gravity from the plastic reservoir located in the 3 point housing. If you are losing fluid there, then there is no hydraulic fluid for any functions. Pull the housing, repair/replace the reservoir and see if your pump starts to work. Hope this helps.
John
