60 JD head leak
LarsD60
09-04-2007 13:17:12
Am working on a 60. Had head off to replace manifolds. Took head into have valves done and checked for cracks, didn't find any cracks. Put head back on used JD head gasket, copper spray on gasket when I put it on, used lead washers, torqued according to specs and sequence. Have been setting valves and took plug out to make sure I was on compression stroke I shined my flash light in plug hole and I see antifreeze in the cylinder. Wondering if I got some copper spray on the fire ring if that would cause a leak or if I have done something else wrong. First time working on two cylinders so I could easily of screwed up. Thanks for any help and suggestions.
Mike M
09-05-2007 04:43:28
 Re: 60 JD head leak in reply to LarsD60, 09-04-2007 13:17:12
Did you take a REALLY close look at the cyl. block walls ? In peticular the upper side of top they like to crack around in a half circle. Torque down the nuts and it pulls it open even farther.
LarsD60
09-05-2007 05:37:47
 Re: 60 JD head leak in reply to Mike M, 09-05-2007 04:43:28
Mike, I guess I didn't look really close. When I took the head off there wasn't any antifreeze in the cylinders. Would a crack have been there before and not leaked until I cleaned everything up aand put it back together? I haven't ran the tractor yet to do a retorque hot would that make a difference. Thanks.
Kemper
09-05-2007 09:43:06
 Re: 60 JD head leak in reply to LarsD60, 09-05-2007 05:37:47
Have you ran this tractor before removing the head?
Is antifreeze in both cylinders or just the one?
Did they plane the head? if so the block may need to be planed also...either way it has to be taken back apart,maybe you can check block with a straightedge,and as mike said check for a crack.
LarsD60
09-05-2007 09:54:05
 Re: 60 JD head leak in reply to Kemper, 09-05-2007 09:43:06
Kemper, Yes I had the tractor running earlier seemed to run okay. No antifreeze in the cylinders when I took it apart to replace manifolds. There is antifreeze about up to the valves in the left cyl and only about a fifty cent piece size of antifreeze in the right cyl. Thanks for your help.
Lars
Mike M
09-05-2007 10:03:03
 Re: 60 JD head leak in reply to LarsD60, 09-05-2007 09:54:05
Well it is possible they screwed up the head too. I once had one resurfaced and it came back worse than it left ! I try to double check this kinda stuff. I got a pretty good starett ruler that's really close. Check down in the ports around the guides maybe they broke something in there ?
