AMOUNT OFOIL FOR A UNSTYLED D
tony w
09-04-2007 08:31:08
I CAN ACROSS A 31 UNSTYLED D AND HAVE NOT FOUND A BOOK ON THIS TRACTOR JUST YET AND WANT TO CHANGE THE OIL. NOT SURE LAST OIL CHANGE, DOES ANYONE KNOW HOW MUCH THEY TAKE SO I CAN BUY ENOUGH TO DO THE JOB? THANK YOU AND HAVE A GREAT DAY.
Jd manuals
09-05-2007 23:26:58
 Re: AMOUNT OFOIL FOR A UNSTYLED D in reply to tony w, 09-04-2007 08:31:08
Link
DIR225 for unstyled D
430WLPG
09-04-2007 18:23:36
It's not the same, it's a 2 speed and has the filter on top of crankcase, But that's a good place to start on the oil
tony w
09-05-2007 06:15:27
 Re: AMOUNT OFOIL FOR A UNSTYLED D in reply to 430WLPG, 09-04-2007 18:23:36
Thanks for t he information, it gives me a great start on what I need to get started. Thanks again.
RalphinWI
09-04-2007 13:06:22
I think(?) it is the same as the styled D, (is it a three speed?). If this is correct, then the capacity is 13 quarts. Buying a 5 gallon pail may cost not more than 13 individual quarts. You will also want to change the oil in the air cleaner. According to my '49 operators manual, 14 gallons of coolant, (make sure the water valve does not leak before adding antifreeze. Also 7 gallons in the rear axle/transmission case. Fuel tanks 23 1/2 gas tank 1 1/2 gal.
