Help!!!
farmboy169
09-03-2007 09:21:07
I torqued my connecting rods to specs. The bearing clearance is perfect at .003, but yet there seems to be a little bit of movement between the crank and rod. Is this normal or should I play with the shims a little. This is the first tractor I have messed around with in 15 years, I can't remember having this problem before. Thanks guys.
johns48jdb
09-04-2007 18:21:17
 Re: Help!!! in reply to farmboy169, 09-03-2007 09:21:07
do they still make plastic gage? it was meant to go in between the crank and the bearings to measure how much clearance there is between them. you put the plastic string in, tightened every thing down to specs and removed the rod caps to see how flat the plastic was mashed. it comes in a wrapper that has a scale on the sides that you could then compare the mashed plastic to, in oreder to see how much clearance you have. way to go as far as i am concerned.
P Browning
09-05-2007 06:08:35
 Re: Help!!! in reply to johns48jdb, 09-04-2007 18:21:17
And to go along with Mike's earlier comment. Plastigage can give a false reading should the bearing be worn out-of-round in the slightest -- this in addition to being hard to used in a JD crankcase. His advise of taking from each side of the bearing one thin shim (0.003-inch) was the most sound way -- especially true for an engine whose bearings are not perfectly round (Just ground). And if, when drawn up, the crank is seized, put the two shims back in, button 'er up, and call it Good! (PatB)
Mike M
09-05-2007 04:51:50
That plastic gage is hard to use on a 2cyl. the parts are soo heavy you can get a false reading and you also have to rotate the crank in most of them to get to the bolts.
Mike M
09-04-2007 07:52:57
Well if you have shims they are .003" so you can only adjust in .003" increments. You can go ahead and try removing 1 .003" shim from the top and bottom ( make sure the stack is equal now )and as you tighten it up try turning it, if it gets tight before the nuts are drawed up then replace the shims you just took out and torque it down put in the cotter pins and call it done.
teddy52food
09-03-2007 19:45:14
Did you mike the crank? Is it round or egg shaped? If it is wore egg shaped it will be loose & tight as you turn it over.
RobMD
09-03-2007 12:04:49
You need clearance for the oil. These old things didn't really have tight clearances anyway.
However, i'm wondering if you should go ahead and take that extra .001 out for a slick fit.
Make SURE you soak the bearings in some fresh motor oil or slick 50 before assembly.
msb
09-03-2007 10:29:54
That dimension is about when you can feel movement. .002 and you would not be able to feel any movement.. You need a little clearance for lubricating oil.
Maark
09-03-2007 10:24:23
With .003 clearance, yes you will have movement at the crank and rod. Probably .003
