JD 3010 transmission question
Bison
09-03-2007 08:18:35
3010 syncro shift tranny,reverse slips out of gear. the syncro discs where broken,and the collar and clutch drum engaging teeth where worn of.
after installing new parts,i found that the shifter fork does not engage the the reverse all the way, cause the fork has a lot of wear in the gap that holds the drum and collar captive.
my manual gives no specs on the inside measurement of this gap.The dealer don't know either.
does any one has these specs,or has a set of new forks kicking around to measure from?
specs on both reverse and low and high range forks will be apriciated.
Green Relics
09-04-2007 10:58:33
 Re: JD 3010 transmission question in reply to Bison, 09-03-2007 08:18:35
Bisson, Back in my younger days when I worked for a John Deere dealer in Ct., I did quite a few Syncro-Range Transmission rebuilds. In order to make these trannies work correctly you need to replace all the syncros, drums, forks and any gears that are severely worn. If you don't replace all these parts, take it from some one who knows, you will have shifting and engagement problems. As a dealer we couldn't risk a bad job because if we had to go back in there it was the dealer paying not the customer. We also would always replace the shifter parts with shifter arms, dash shifter parts, and all egged out yokes. It was expensive but it worked like new when we were done. These Transmissions have very tight tolerences. If parts are worn it won't shift or stay in gear. To make a long story short don't worry about the drum and fork tolerences, just replace them or you'll be back in there in a short while fixing something else. John
Tx Jim
09-04-2007 04:40:12
 Re: JD 3010 transmission question in reply to plibbert, 09-03-2007 08:18:35
Bison,I would think that the spec's you are wanting would be in the JD tech manual for 3010. I looked up the parts in JDparts.com and it didn't show any spec's for those part #'s. Tx Jim
