JD 112 Steering problem
Xrayspecs
09-02-2007 13:56:54
Help! Just got a '68 JD 112, and while mowing there was a "click" and now the tractor can only turn right. If you turn the wheel to the left, it appears that the steering column unscrews and backs out without turning the wheels to the left.
What could this be?
Xrayspecs
09-03-2007 10:59:41
 Re: JD 112 Steering problem in reply to Xrayspecs, 09-02-2007 13:56:54
Thanks guys, I'll have a look and let you know!
Bob
09-02-2007 20:39:46
There's a ball thrust bearing, and a simple race above and below the steering worm. The balls may have simply gotten out of place ('cause of too much endplay), letting the worm move upward, or the race ot the steering gear housing itself may have broken. The steering gear will have to come out, and come apart to see what's going on.
Michael Sheik
09-02-2007 17:17:54
Had one of these for a lot of years but sold a year ago. Great tractor and it has style! I assume you are saying the shaft attached to the steering wheel is coming up out of the sector. I was never actually in this other than to adjust the sector but I would bet either a nut on the end of the shaft or maybe a lock ring that come undone. You really need a service manual that shows the exploded view of the sector so you can see how it is all put together. Money well spent from JD. You may get someone to post a picture for you. Get that book!
