35 D
r.c.p.
09-02-2007 06:34:25
having trouble starting a 35 D.once it starts it runs like a million.have done all the obvious,timeing,plugs,fuel and mag.someone must have a secret that i have missed,thanks for any info. bob
70DLee
09-03-2007 21:46:41
 Re: 35 D in reply to r.c.p., 09-02-2007 06:34:25
I have my great grandfathers 1935 B and was having a similar issue with it. Come to find out, I was able to learn a trick that has been priceless. My Grandfather showed me that to shut the tractor down, first, turn the fuel off. Have the engine at 1/2 throttle and close the choke. by choking it until it dies, This will prime the cylinders for the next time you go to start it. My B starts first crank every time!
Ken L.
09-02-2007 15:24:18
I have a 27 D and I have found that the easiest way to start it is to shoot a little either into the petcocks when the pistons are on their way back on the intake stroke. That way the either atomizes better because of the incoming air. Unless you want to crap in your pants, do NOT shoot the either in when the piston is on it's way forward on the exhaust stroke. Believe me when I say that if you do that you will probably need the rear seam of your pants resewn if there is anything left of them.
r.c.p.
09-03-2007 20:10:27
 Re: 35 D in reply to Ken L., 09-02-2007 15:24:18
KEN,
thanks for the info on starting a d.i am not much of an either fan for gas engines so i tried wd40,it works fine on my D. bob
