4230 scv
matt p
09-02-2007 06:15:03
Hi i have a problem with a scv on my 4230 for some reason the casting split on the rectangular tunnel wich i persume is the pressure free return
and pumed out oil. i have a new one to put on but i think i may have another problem which caused it to split it has 2 scvs and it is the right hand one any ideas would be much appreciated Matt
Doug in IL
09-02-2007 19:25:52
 Re: 4230 scv in reply to matt p, 09-02-2007 06:15:03
Matt, did you just add this remote onto the tractor? If you did, I probably know what's wrong. If it's always been there, I don't know.
matt p
09-03-2007 12:52:42
 Re: 4230 scv in reply to Doug in IL, 09-02-2007 19:25:52
it is a scv that i added 3 years ago i had a sandwich plate too which fitted in between the scv and the top cover it seemed to work ok but it broke using a flow and return on a motor which i know it isnt designed for but always seemed fine any help wuld be greatly appreciated
Doug in IL
09-04-2007 06:39:34
 Re: 4230 scv in reply to matt p, 09-03-2007 12:52:42
I added one to a 4030 some years ago. I also broke that housing. But mine cracked almost immediately. I came to find out that the earlier serial numbered tractors use a different adapter plate than the later ones. The earlier adapter plate uses an external drain port with a hose going back into the rock shaft housing. I don't know if the 4230 was the same setup as the 4030 or not. You might check your JD dealers parts diagrams to see for sure. I had a bit of a time finding the earlier adapter plate, used. Finally found one thru the salvage yards online parts system at a yard in Alabama! I think they were still available new also, at that time.
