2020 hydraulic fluid service issue
henhawk
09-01-2007 11:36:01
I have a 2020 with a 146 loader installed, I checked the dip stick and it does not show any fluid on it. Is the servicing port for the hydraulic fluid the cap directly behind the seat. That appears to be where you would put in the 90 weight oil for the rear end. I have ordered a service manual from Deere but they say I am about 4 weeks away from getting it. New owner , just do not want to make one of those bad mistakes early on.
Bob
09-01-2007 22:36:57
 Re: 2020 hydraulic fluid service issue in reply to henhawk, 09-01-2007 11:36:01
Your post sure makes it plain why having an operator's manual for every tractor you own will save you $$$$ in the long run!
donmyeil
09-01-2007 13:43:00
The dipstick is by your right heel. Yes the fill hole is behind the seat. Use John Deere Hy-Guard hydraulic oil. This tractor does not use 90 wt oil at all.
