J.D 730 GAS OIL FILTER PROBLEM
GARY M
08-31-2007 14:01:35
THE BOLT THAT HOLDS THE OIL FILTER BOTTOM COVER IS STRIPPED IN THE UPPER CASTING OR WHERE IT BOLTS INTO. I CAN"T TIGHTEN IT ENOUGH TO KEEP THE OIL FROM DRIPPING OUT. IT WAS THIS WAY WHEN I BOUGHT IT. WHAT KIND OF PROBLEM IS THIS TO REPAIR OR REPLACE.
teddixon
09-01-2007 08:12:45
 Re: J.D 730 GAS OIL FILTER PROBLEM in reply to GARY M, 08-31-2007 14:01:35
The oil filter body is pressed into the crankcase. Drain oil from crankcase and remove oil filter cap and the element. You will have to open the crankcase cover. I don't know if it's possible to do it with the rods still connected. My 70 book says that rods will have to be disconnected from crank. Once all that is moved out of the way you will have to disconnect all the oil lines from filter head. This is tricky as you usually have to "make" wrenches fit in this area. Once lines are loose, you have to also remove the outlet tube under the tractor as it is covering the cap screws holding the body and filter head together. Book says to construct a 18" long 3/16th diameter rod that will reach up into body to remove the outlet tube. It is bent into a "U". Once outlet tube is out you can use a ratchet to remove cap screws to separate body from filter head. There are some other posts on this subject I know. There will be others who know more than I do who will probably post back. Good luck.
markiees
09-01-2007 07:36:29
I think you need to get the filter houseing canister out....not the easiest thing to do....for me anyway...
