Hydraulic problem on articulated JD 8630
Dick 68
08-31-2007 05:00:32
As I plan the acquisition of a big tractor I recently went to see an articulated JD model 8630 (one of the last produced with SN 8130). I seems to have an hydraulic problem since when raising the rockshaft it lifts slowly and chatters. The owner said that although he had checked the oil level, replaced the oil filters and had cleaned the charge pump screen the problem hadn�t gone. Furthermore I also noticed that when holding firmly the steering wheel the steering column is chattering too even when not steering the wheel and not trying to raise rockshaft. However the tractors steers very well and quite quickly but when you lift rockshaft and steer at the same time then the rockshaft immediately stops raising. Does any one have any idea on where the problem could be ? Is it likely that there is a leak in the steering valve and as the steering circuit has priority then all the flow is by passed over there ? The tractor only tachos around 6000 hours,. Would that be a typical problem on these tractors ? Furthermore there are very slight oil leaks around the cylinder head gasket (mainly on the right hand side). Would that be a sign of an imminent gasket failure ? Any advice would be welcome.
rexhellwig
08-31-2007 16:07:48
 Re: Hydraulic problem on articulated JD 8630 in reply to Dick 68, 08-31-2007 05:00:32
"Any advice would be welcome."
I advise you to find another tractor.
Tx Jim
08-31-2007 05:17:23
First thing I would do is check trans. pump pressure. Should be about 175 psi. Then check main pump stand-by pressure. Should be 2250 psi. Could be a weak stroke control valve in main pump. Tx Jim
