630 JD power steering foams over
D colton
08-30-2007 21:55:09
630 row crop, p/s fluid bubbles up and spits out of the dip stick vent (when warmed up only) I put the correct jd p/s fluid in and fixed any external leaks, the p/s works good. the fluid is foamy whem hot. any suggestions?
RobMD
08-31-2007 16:14:43
 Re: 630 JD power steering foams over in reply to D colton, 08-30-2007 21:55:09
I agree with blksmoke... BUT, it can ALSO be (MORE THAN LIKELY) that the pressure of the oil is bypassing the steering vanes and going into the reservior.
It's happening right now with a rebuilt power steering pump... it's in my vanes that this is coming from. I have yet to pull it and fix the O-rings and stuff down there.
Blksmok
08-31-2007 05:06:57
D colton...your p/s pump needs new seals ( and maybe a main shaft). It's sucking air through the seals and foaming your p/s fluid.
