john deere lawn and garden tractor 430
augustus
08-30-2007 19:23:01
stopped cutting grass-blades wont turn...is it a belt and is it a hard job?
Handsome Jim
08-31-2007 16:27:25
 Re: john deere lawn and garden tractor 430 in reply to augustus, 08-30-2007 19:23:01
The deck shouldn't be too hard to take off IF you have a manual. I've taken decks off my mowers and my mom's many times for PM and I still wouldn't attempt it without a manual. But just a hint, if the mower drive belts aren't turning, it's probably the electric clutch.HJ
augustus
08-30-2007 21:53:40
tractor runs ok... problem happens when I lower hydraulic levers to mow and cut -nothing happens and blades dont turn..do not have manual and want to fix it myself..need a little help telling me how to take deck off and if the belt might be the problem... sure would appreciate some advice fellas...
Rich Va
08-31-2007 05:46:15
 Re: john deere lawn and garden tractor 430 in reply to augustus, 08-30-2007 21:53:40
Is your electric pto clutch working?
RobMD
08-30-2007 19:40:15
Have you been maintaining the tractor? I ask this because if the mower suddenly stops, it could be a broad range of possible problems.
Don't you have a manual? I'm sure it would tell you how to take the mower off and change the belt if needed.
Anyway, to hypothetically answer your question, a mower suddenly stopping MAY mean that you:
A) weren't greasing the bearings,
B) letting the mower deck plug up full of grass,
C) burned the belt off or let trash collect on the deck,
D) your mower gearbox ran out of oil,
E) your tractor has severe pto/transmission problems
In other words, pull the deck and find out for yourself!
