1010 Brakes
Vermont John
08-30-2007 18:26:06
I have a 1010. The brakes stink. The manual tells me to take it to the dealer, but they are not really interested in working on it. Any tips for me, other than getting another tractor.
People knock these things. However, once properly maintained, it is not bad!
Vermont John
09-08-2007 05:22:43
 Re: 1010 Brakes in reply to Vermont John, 08-30-2007 18:26:06
Thanks for all the information. I will try lengthening the brakes.
I would not tow any weight with this machine due to the brakes. The owners manual kind of warns you about them. My land is flat. Still, I will not run the thing in more than 3rd gear, and usually 2nd.
When I said the tractor was not bad, I meant that mechanically. Mine is a 1963, when they had worked out some of the bugs. It has 8500 hours. The engine seemed tired when I bought it from a Kubota dealer. Only, those Kubota mechanics had never heard of a tune up. I changed the coil, plugs, wires, etc. It starts and runs pretty well now.
EMG
09-02-2007 05:19:47
I have a 2010 and I lengthened the brake arm where the pedal linkage attaches in the back. You can bolt on a 1" long piece of steel to the current attacment point and move where the linkage attaches down by 1" which will give you more leverage. The brakes are still bad but this did help a bit.
Jim Miller
09-10-2007 19:27:17
 Re: 1010 Brakes in reply to EMG, 09-02-2007 05:19:47
When I was a kid we had a new 2010 and I don't remember the brakes as being a problem. I bought one a couple of years ago and the brakes are terrible. I disassembeled and cleaned everything, I even had the stator plates blanchard ground without any improvement. What's the deal with the 1010 parts?
Loren NC
08-31-2007 12:52:49
My dealer told me the same thing, but in my case it was the hydraulic system they would not touch. You can repair the brakes yourself and they will be better, but they are so tiny that they will never be good. I worked mine over and they work better. Fortunately, I don't have significant hills or heavy equipment to worry about.
08-31-2007 05:49:37
Not bad? Depends on your definition. We had customers that came close to getting killed - coming down hills with loaded hay wagons and NO brakes. You can maintain a 1010 all you want and it won't fix the design flaws. The brakes on 1010 wheel tractors never worked, not even when new. I worked at three different Deere dealerships since the 1960s - and everybody had different ideas - or attempts - to improve the brakes on 1010s and 2010s. NONE worked in the long run. Standard procedure used to be - to cut spiral grooves into all the steel plates to help prevent glazing. But, regardless - there was never a 1010 wheel tractor built that had enough brakes to stop - coming down a hill will a trailer or implement hooked to the back. I wonder what Deere was thinking ?? - the manual brakes in an older 430 tractor worked much better, and the power brakes in the following 1020 were much-much better. It may of been Deere's first attempt to use ball and ramp actuated disk brakes - and it did not work. At the same time, Case was also using it - but the Case brakes were much better designed. In general - the 1010/2010 series represented several "firsts" for Deere - including using the first diesel with a rotary Roosamaster injection pump in 1960. The wheel tractors were poorly designed - but the crawlers had many good innovations that were carried on into the 350 and 450 series for many years.
Bison
08-30-2007 19:10:28
You say your brakes stink,do they smoke too and how hot do they get.
it sound like they are dragging,could the pedals or the linkage be stuck,or return springs broken or lost. If they are hydr,a stuck brake valve?
I ain't familiar with a 1010,but brake workings are largely the same across models or brands.
someone else will pipe in I trust.
